Judging from the "JAPAN" font, I think it is a NEC microcontroller.
It maybe uPD78F0138.
Compare from the position of the power supply pins, etc. If they are in the same position, they probably are.
Since it is a MaskROM, I don't think you can dump the firmware. It may be better to give up.
I compared it to other NEC microcontrollers, but it has the distinctive #1 pin identification marking. I am sure it is correct.
