Author Topic: Bluetooth speaker module (spk md blk-b)  (Read 2437 times)
Offline Lee_horner93Topic starter
« on: June 13, 2018, 06:39:37 am »
Hi folks! I've been working on a a small Bluetooth project, creating a set of Bluetooth headphones, using the Bluetooth speaker module spk md blk-b that I purchased a few weeks ago from  somewhere in China. Unfortunately I can't find any proper wiring diagrams or schematics for this specific chip, I will attach a few pictures. The problem is I can't seem to power the chip up no mater what I try, and I have tried with two separate modules.
I have seen diagrams of similar modules that feature a multi function button (mfb) that requires a long press (3sec) from the power supply to power it up. If anybody has any information on the chip that I have or know off any other methods to try and power it up that would be great!
Offline Buriedcode
Re: Bluetooth speaker module (spk md blk-b)
« Reply #1 on: June 13, 2018, 12:18:23 pm »
Depending on which diagram you provided is your module, you need to pull the "Vreg" or "MFB" line high - to Vbatt via a 10k resistor will do.  MFB = multifunction button and is usually the "pairing/power on/off" button on bluetooth audio devices.  It is also sometimes referred to as Vreg, even though it is an input.  It is essentially what powers up/down the internal 1.8V regulator which powered the chip.
I assume you mean this module: https://www.elecfreaks.com/wiki/index.php?title=BLK-MD-SPK-B
« Reply #2 on: June 13, 2018, 01:10:26 pm »
Thanks for the response! Apologies the top image is the board I have, with the charging pins across the bottom. I will try this later. You wouldnt happen to know if the 1.8v circuit earths on the same pins as the 3.3v circuit?
Sent from my SM-G935F using Tapatalk
Offline Buriedcode
« Reply #3 on: June 13, 2018, 01:20:15 pm »
Yes, all the grounds should be connected.  The 1.8V comes frm the module (on-board voltage regulator) but the 3.3V is supplied externally.  It is designed to run from a lithium polymer battery so 3.3-4.2V on Vbatt.  So for your module, Vbat is 3.3V in, and "Vreg" should be connected to Vbat by a 10k resistor.
« Reply #4 on: June 13, 2018, 05:33:23 pm »
Just tried tried pulling the Vreg pin high and it works perfectly! Thanks very much!
Offline suraj
  • Country: in
« Reply #5 on: August 28, 2018, 06:23:02 am »
need a help to design a low cost bluetooth speaker. It will be very helpful if you provide me a refrence circuit daigram
