Author Topic: BMS cell multiplexer  (Read 360 times)
Offline chota.sanjiv
  • Country: in
« on: January 05, 2019, 01:22:40 am »
Hi Guy,
I am trying to create a mosfet based multiplexer controlled via opto-isolated MCU control, the object is to connect any li-ion Cell out of a series pack to a CC load whenever required. I got it working by using diodes to stop the reverse current (as +tive of one cell becomes -tive of the other) but I want to eliminate the use of diode and used mosfet based circuit only (can load more current and also less voltage drop).
I would appreciate any suggestions.
Offline Kleinstein
Re: BMS cell multiplexer
« Reply #1 on: January 05, 2019, 01:42:45 am »
Maybe photo-fets could work.  This are opto-couplers with a FET  output part.
  • Country: in
« Reply #2 on: January 07, 2019, 06:29:14 am »
they might, but looking for a cheap soln which can handle 10A of current per cell.
Offline jonroger
« Reply #3 on: February 25, 2019, 11:38:55 am »
The EMB1428Q provides all the gate drivers you need for mosfets to connect any one of a series string of batteries to a single connection.
