Author Topic: selecting a switchmode IC based on pinout?  (Read 593 times)
Offline src1989Topic starter
  • Country: scotland
    • SRC Events
« on: January 27, 2022, 03:07:58 am »
i'm looking for websites i can put pin numbers/configurations into to find a compatible switchmode chip; original DIP-8 IC has no part code.
Pins 7/8 are commoned and are connected to the rectified mains via the primary winding. Pin 1 comes from rectified mains via a 3.3MegOhm resistor. pin 3 is GND. pin 4 N/C. etc. need to investigate the board again tomorrow...
Offline elektrolitr
  • Country: lv
Re: selecting a switchmode IC based on pinout?
« Reply #1 on: January 27, 2022, 05:42:12 am »
I used this
https://remont-aud.net/ic_power/
May be outdated, but so do most of the PWM chips
The following users thanked this post: src1989
  • Country: scotland
    • SRC Events
« Reply #2 on: January 27, 2022, 04:12:13 pm »
cheers. i was getting confused by it's use of DRV. think i've found 2 compatible ICs...
