check +5V presence then activate supply by putting some resistor between PS_ON and +5V ()small, like below 100ohm you already have the 10kohm).
seems like that higher side psu is outputting the standby voltage.
if no +5V, then dig for this standby voltage. you can put some load on +12/+24v outputs or just use the TV boards for this
IC902 is my main suspect, or something around him
