Author Topic: Common ground between ATX power supplies  (Read 1304 times)
Offline bitmanTopic starter
  • Open Source Guy jabbing with Electronics
« on: December 05, 2020, 11:30:34 pm »
On my bench power supply I have common ground. I even connect one bench supply + to another's - to get multiple voltages for the same project. It works, I know how and it's very helpful.
But I'm in the need to temporary add a second ATX power supply to a computer while I add more drives to migrate off the existing ones. The current supply is too small to handle this, so my plan is to just power the new drives temporarily from a second supply, move the data, remove the old ones and go back to just one PSU.  But I need the two supplies to have common ground as the drives connect to the same motherboard.  Is there anything on a standard ATX power supply that would prevent this from happening? Ie. if I connect the ground lines from one to the other, will this cause some safety in the ATX supply to go "nope - cannot do that"?
Perhaps the better question is: How can I tell without risking blowing both supplies up in the process?
Offline msat
Re: Common ground between ATX power supplies
« Reply #1 on: December 05, 2020, 11:50:52 pm »
It should work "in theory". I wouldn't rely on the grounds being shared strictly through the IEC power cables, though. Instead, find a better way to bond the PSUs together. Then check the resistance through the ground terminals on drive power connectors between the supplies, to ensure there's no unusually high resistance. But I wouldn't try it on my word alone because I've never tried it myself.
Offline golden_labels
« Reply #2 on: December 06, 2020, 01:08:22 am »
For short tests: I was doing that many times in my life with no issues. As a permanent solution: I would be careful, but this is not a “will not work”.
For power hungry components the current goes through the same plug both directions, so each of them is always powered from a single PSU. The ground connection is there mostly to provide common reference for signals. The main concern are motherboards with multiple connectors and PCI-E cards, as they share power lines. Be sure to connect them all to a single PSU.
People imagine AI as T1000. What we got so far is glorified T9.
Offline m k
« Reply #3 on: December 07, 2020, 11:08:14 am »
I've temporarily used second PSU by just putting it on the floor of a standing metal case.
It should be totally ok if you bolt metal cases together, with or without the decent wire.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
