I've have numerous cases where Mouse and DK sold me less, more, incorrect or damaged parts.
To be fair, that doesn't happen often. I make ~20 orders from each of them each year, and on average I have only one issue per year, so not a big deal.
At the end of the day, you are going to QC the parts. I presume they don't sell fake, so what I care are just broken, wrong P/N, less QTY or extra parts.
I buy mostly from Digi-Key, and also Mouser and Newark. A long time ago, somebody at Digi-Key was stealing parts, and a BUNCH of cut tape orders were coming up short, like half what I ordered. I guess their security people eventually figured out who was doing it and canned them. Otherwise, I have had VERY few errors from any of the above. I did get the wrong regulator once, it was supposed to be fixed 5 V, and I got the adjustable regulator version. One other issue was for a time they were taking FPGAs out of the Xilinx tray and repacking them in little tiny cut tape strips of 5, which I then had to put back in trays to run in my P&P machine. In all that handling, fragile leads could get bent a little.
I just reflexively do static-safe handling, grabbing the bench before touching any devices or boards, and keeping all sensitive parts in static-safe
packaging of some sort. I almost NEVER have problems like you report. I've probably built gear with 100K ICs over the last 40 years, and can
count on one hand the number of bad parts I have encountered when there was no reason (improperly connected power supply, wrong signal connection, part soldered on in wrong orientation, etc.)
I did have one incident when buying a bunch of Analog Devices op amps from a major NON-franchised distributor. After mounting 25 of these chips on a board, half of them blew up. AD had recently changed their marking/logo and put their triangle logo near the pin 5 side of the chip. I suspect another assembler put bunches of chips in their P&P machine backwards, and assembled boards. Then, after massive failures, they scrapped the boards, the chips were picked off and cleaned up, and re-reeled. After talking with AD, I thought to ask, was it possible for a reel of ICs to have varying date codes? They said that was ABSOLUTELY impossible in their process, and clearly indicated the parts were either counterfeit or salvaged. So, I swore to NEVER, EVER, deal with that outfit again.
But, other than that, I have had great reliability when buying parts from the major, franchised distributors. I know that in the past, Newark scrapped all returned merchandise, as ourt local surplus outfit bought it by the pallet load. Some of it was bad, like power supplies, but most of it was fine and just "ordered the wrong part". But, refusing to restock anything that has been opened should keep their stock pure of counterfeits and damaged parts.
So, I'm guessing you have caused static or electrical overstress damage in your experimenting.
Jon
