Author Topic: What IC is it?  (Read 1098 times)
Offline JaneTopic starter
What IC is it?
« on: June 20, 2023, 08:09:02 am »
I need to repair a charger, for e-bike, made by Stchargers.com.
There ,SMD IC marked  71427 seems to be faulty. That IC is marked U1 in the picture.
Input voltage seems to be on pin 6 only( there is 12V), other voltages seems to be zero.
Anyne knows what IC it is?
Thank you.
Offline m k
Re: What IC is it?
« Reply #1 on: June 20, 2023, 09:01:10 am »
Can't say, picture is too abstract.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Re: What IC is it?
« Reply #2 on: June 20, 2023, 09:48:13 am »
Here is a picture
Offline m k
Re: What IC is it?
« Reply #3 on: June 20, 2023, 10:20:42 am »
PWM controller is an obvious first guess but details are avoiding.
Re: What IC is it?
« Reply #4 on: June 21, 2023, 01:46:33 pm »
I added few more pictures. I removed IC (I  marked  the place with red).
It is an e-bike charger SHC-8100L
The unknown IC ( marked U1 there) is size of 3x2mm
« Last Edit: June 21, 2023, 01:51:19 pm by Jane »
Offline Terry Bites
Re: What IC is it?
« Reply #5 on: June 21, 2023, 02:34:23 pm »
Hmmm, an LDO seems likely....
Offline m k
Re: What IC is it?
« Reply #6 on: June 21, 2023, 03:46:49 pm »
So pin 2 out and 3 maybe a feedback,
4 and 5 a time constant, with shut off from U2,
then 1 and 6 for power.
Offline ArdWar
  • Country: sc
Re: What IC is it?
« Reply #7 on: June 21, 2023, 05:11:52 pm »
Whatever it is, it's:
  • Driving a 650V NMOS thru Q2, so probably a PWM controller
  • Pin 2 is DRV
  • Not your usual SOT23-6 flyback controller since they usually have DRV on Pin 6
  • Pin 5 is probably FB
Offline m k
Re: What IC is it?
« Reply #8 on: June 23, 2023, 09:31:07 am »
Quite a bugger, only 6 pins and half clearly known.
I'd say that get a new charger and leave this to rainy day modding project, if it's not already.
1 GND
2 GATE
3 SENSE
4 FB1
5 FB2
6 Vcc
FB seems to have at least CC, CV and zero crossing.
SENSE is not very straight forward.
Other version has through hole C1, it also have few underside traces.
Few guesses.
There underside C7 GND connects to C1, here the hole.
There Vcc and pin 3 goes to other side of the board, here 0R and C2 holes to R17 and R18 holes.
Maybe SENSE is also indicating an AC present.
TI should have all kind of oldies available, if the used chip is a copy it's probably from something older.
But all I found was one SOT23-6 secondary side PWM, UCC82742.
Maybe the chip is not in its primary use.
Offline m k
Re: What IC is it?
« Reply #9 on: July 03, 2023, 04:10:31 pm »
Seems that "drive by" viewing revealed something.
OB2532 has quite exact pinout, some others also.
But all are for primary side, and GATE and SENSE are just regular style.
One other thought, maybe it's originally for BJT.
Re: What IC is it?
« Reply #10 on: July 04, 2023, 08:44:00 pm »
Thank you for replies.
@m k:
Can you please explain more what  you mean by
and
What is BJT ?
Offline m k
Re: What IC is it?
« Reply #11 on: July 05, 2023, 02:38:40 pm »
Regular style is how typical application is connected, directly to FET and nothing else.
BJT = Bipolar Junction Transistor
FET = Field Effect Transistor
In my head transistor is transistor and FET is FET but that is not exactly accurate.
