I'm currently working on an under-performing left channel of a Dynaco SCA80Q I built as a high school kid back in the late 70s. I can follow directions, and have built quite a few kits (Dynaco, Hafler, Audio Concepts speakers, and most recently an Akitika PR102 preamp), and have done a lot of board repopulating and replaced all of the large caps on the Dynaco in the past month or so. However, I don't know much about electronic circuit analysis or theory, although I'm making a concerted effort to learn, and have purchased a Siglent SDS1202X-E and am slowly getting comfortable with it as my first introduction to scope usage. For anyone interested or willing to comment or help with the Dynaco specifically, this thread details the issue I'm trying to pinpoint...
https://audiokarma.org/forums/index.php?threads/dynaco-sca80q-issue-s.988842/In general, I'd like to know more about choosing appropriate substitute transistors. I've downloaded datasheets transistors from alltransistors.com and used their substitution recommendation pages, and have also read various websites for help with this, but many of them say things like, "choose close to the value of your current transistor," without specifying exactly what "close" means, or saying that it's OK to exceed a certain value, but not by how much. I've gleaned that exceeding the Ft of an existing transistor can lead to oscillation in a circuit not designed for a transistor with a higher limiting value, but confess I still don't really understand what is OK in terms of a lot of the other specifications and what isn't, nor the hierarchy of importance of each specification match.
The transistor I'm having trouble matching is Q1 on PC-18 of they Dynaco, specified as a BC108A transistor, "BC108A 170-2@ Beta @ 2 ma" in the manual. I've attached a datasheet if it's of any use. The BC108A is not available on digikey, nor are any of the close to identical matches shown on the alltransistor substitute recommendations. What matters? What doesn't? How close does "close" have to be? What would be a good, available substitute for a BC108A used in the Dynaco circuit?
Another source of embarrassment - diodes D2 and D3 on the same board are spec'd as silicon diodes, "0.8 volt max. drop @ 140 ma." I can't find a single "silicon diode" on digikey... what the heck am I doing wrong? Same thing as a "standard" diode? Looking at some "standard" diodes, I can't tell what spec I should be looking at to match the Dynaco manual description. Can anyone offer guidance there, too, please?
Thanks for any help... much appreciated.
