Author Topic: I need help identifying some components("DDR", "SAF")  (Read 294 times)
Offline cold_zeroTopic starter
« on: June 08, 2024, 05:48:42 am »
I need help identifying some components on the motherboard of a GoPro camera. I have taken pictures of them.
    The first component is labeled "DDR" and is connected to the camera lens.
    The second component is labeled "SAF" and is connected to the USB IC. One of its pins has 5 volts.
I have attached the photos of these components.
Thank you
Offline exmadscientist
  • Technically A Professional
Re: I need help identifying some components("DDR", "SAF")
« Reply #1 on: June 08, 2024, 06:23:31 am »
The following users thanked this post: cold_zero
« Reply #2 on: June 08, 2024, 07:16:40 am »
thank you
