Hello,
I am about to design a little PCB module with Bluetooth. This will be permanently connected to a 12V 40Ah battery in rural areas.
The goal is to enable voltage measurement of the battery using Android phone without touching the battery and module.
Also, the power consumption of the module must be very low - to enable a month or longer job without charging the battery at all.
What module (ESP32 ?) will fit my goal best ?
