Author Topic: ESR Meter  (Read 2600 times)
Offline ramin110Topic starter
  • Country: ir
ESR Meter
« on: March 02, 2018, 09:07:44 am »
I designed my first PCB inferring from Alan Wolke ESR METER schematic but mine is not working, I haven't an oscilloscope to measure the waveforms output but at least I have a multimeter and I had checked the oscillator section works around 140 kHz. I know I made a mistake in my schematic but I fix it but still not working.
here are pictures of Mr Alan Wolke design and mines.
Thanks for any helps
  • Country: ir
Re: ESR Meter
« Reply #1 on: March 02, 2018, 09:10:11 am »
alan wolke video and picture about this ESR meter:
picture of his design:
« Last Edit: March 02, 2018, 09:37:49 am by ramin110 »
  • Country: ir
Re: ESR Meter
« Reply #2 on: March 02, 2018, 09:17:30 am »
Mines:
3d view:
my schematic:
my PCBs:
« Last Edit: March 02, 2018, 09:37:21 am by ramin110 »
  • Country: ir
Re: ESR Meter
« Reply #3 on: March 02, 2018, 09:24:42 am »
here is the real PCB:
sorry for the brevity of my description because I'm not native English speaker  :-X
« Last Edit: March 02, 2018, 09:36:56 am by ramin110 »
Offline w2aew
    • My YouTube Channel
Re: ESR Meter
« Reply #4 on: March 02, 2018, 03:27:24 pm »
The DC Restore circuit will not work with the LM358.  The AD8032 was used because its input common-mode range extends below the negative supply (ground), and the output doesn't exhibit phase reversal when the input voltage differential gets large (in open loop operation).  There are likely other single supply rail-rail op amps that would work, but the LM358 isn't one of them.
« Last Edit: March 03, 2018, 12:20:45 am by w2aew »
FAE for Tektronix
The following users thanked this post: ramin110
