Author Topic: Boy, I know even less than I thought about diodes  (Read 796 times)
Offline rp58Topic starter
« on: February 27, 2022, 08:08:56 pm »
Can someone please explain how this simple circuit:
1426294-0
can generate this waveform?
1426300-1
That's an almost dead 12v SLA, a 50v 3A diode, and the scope is dc coupled. When I flip the diode it conducts and displays normally.  The frequency looked suspicious, but it does not equal my mains frequency which is 59.56
The following users thanked this post: Capernicus
Online xrunner
  • hp>Agilent>Keysight>???
Re: Boy, I know even less than I thought about diodes
« Reply #1 on: February 27, 2022, 08:14:55 pm »
Just picking up 60 Hz noise from the surrounding lines. The battery/diode has nothing to do with it per se, except acting as a slightly better antenna.
Online ataradov
    • Personal site
« Reply #2 on: February 27, 2022, 08:16:28 pm »
And you can't rely on the frequency value as measured by the scope. It is on the ballpark of the 60 Hz, it is mains.
Alex
« Reply #3 on: February 27, 2022, 08:43:47 pm »
Ok, got it.
As a follow-up, what I was preparing to do was protect my benchtop power supply while I reverse charged this battery.  But then I realized there is no way to do that, is there?  You can use a diode to forward charge a battery, but how do you protect the power supply for reverse charging?  (This is an experiment in desulfation)
Online ataradov
    • Personal site
« Reply #4 on: February 27, 2022, 10:04:25 pm »
No, your power supply need to be able to sink current. Many supplies can do this, but usually for a limited amount of time.
Alex
