Author Topic: Breadboard power termination  (Read 1541 times)
Offline netdudeukTopic starter
« on: March 26, 2019, 11:45:44 am »
Hi
What does anyone do to terminate multiple power rails (e.g. 5v, +9v, 0v, -9v) for breadboards ?
I know that there are things like this https://uk.rs-online.com/web/p/breadboards/8352712/, and boards that have 4mm sockets on their baseplates, but they don't seem to add much value.
Thanks
Online tggzzz
Re: Breadboard power termination
« Reply #1 on: March 26, 2019, 04:08:46 pm »
Just stick the wires in directly.
If you are using solderless breadboards you are already in a state of sin, so one more "suboptimality" won't be noticed.
Alternatively consider that every non-soldered connection is a problem waiting to surface, so it is not a good idea to add unnecessary connections.
Have fun debugging your solderless breadboard (with parasitic and varying L,C,R); after that you can move on to debugging your circuit.
Offline zirconx
« Reply #2 on: March 26, 2019, 05:22:50 pm »
I discovered these recently: https://www.ebay.com/itm/3X-MB102-Breadboard-Power-Supply-Module-3-3V-5V-for-Arduino-Bread-Board/222743649206
it plugs into your breadboard and provides either 3.3v or 5v on both sides.
I ordered one. Will be here in a few weeks.
« Reply #3 on: March 26, 2019, 10:12:25 pm »
I have quite a few I’d those thanks but I’m referring to multiple rails.
« Reply #4 on: March 26, 2019, 10:13:20 pm »
Yes.  Factor in the fact that these are Chinese ones and you get to have even more fun  :)
Offline Doctorandus_P
« Reply #5 on: March 27, 2019, 12:22:55 am »
A long time ago I used a piece of 10 pin male 2.54mm header.
Soldered 5 wires to one wire, and the 5 others to the other wire.
Because of the 10 pins and the low profile it's sits solidly in the breadboard.
Added a loop from solid 2.5qmm mains wiring.
With the loop you can easily pull it out the breadboard and it is also a GND connection for your oscilloscope, DMM, etc.
Also added a bit of yarn and glue to increase it's longevity.
« Last Edit: March 27, 2019, 12:24:55 am by Doctorandus_P »
The following users thanked this post: odessa
Offline zirconx
« Reply #6 on: April 06, 2019, 02:29:28 am »
Because of the 10 pins and the low profile it's sits solidly in the breadboard....
Doctorandus that is brilliant.
I sometimes use these jumpers I made, I soldered on a stub of stiff wire from a resistor, for example. Plugs right into the breadboard.
Online radiolistener
« Reply #7 on: April 06, 2019, 05:33:12 am »
This is how I do  ;D
