Hello! I'm trying to wire this (probably very simple!) switch, but can't find any documentation.
I find similar rockers, but any with wiring diagrams seem to have some indication of their vertical orientation. i.e., You can tell 'up from down' as it were, because they have a space (empty plastic surface) at one end.
This mini seems symmetrical top to bottom, so I'm not sure which is in/out and which side is +/-.
I'm guessing the plastic tab between the two pins that are closest together perhaps indicates this? But I'm just guessing.
Any way of discovering this? Thanks for any info!
