Author Topic: bridge or center tapped rectifier question (Is it obsollete?)  (Read 1019 times)
Offline 001Topic starter
  • Country: aq
« on: November 19, 2018, 10:29:53 am »
Hi!
I see that simple brige rectifier is ok for most of classic PSs
But what about advantage of "center tapped transformer + two diodes" and "center tapped transformer + brige" circuits?
Is it obsollete?
Offline mvs
Re: bridge or center tapped rectifier question (Is it obsollete?)
« Reply #1 on: November 19, 2018, 11:54:14 am »
On the one hand less diodes means better efficiency and less heat. On the other hand it requires more copper in the transformer.
This rectifier topology is commonly used in SMPS supplies (push-pull, half-bridge, full-bridge topologies), since at high frequency the transformers are small, and copper usage is not a concern.
It is useful for dual power supplies, since center tap is half voltage point. You will find this rectifier for example in audio amplifier or linear lab power supplies. Or even in power supplies of PCs to generate +12V and -12V rails (with unsymmetrical rectifier, 2 large Schottky diodes for +12V rail and 2 small diodes for -12V rail).
The following users thanked this post: 001, Richard Crowley
Offline floobydust
« Reply #2 on: November 19, 2018, 07:14:22 pm »
Full-wave center-tapped (two-diodes) is no longer popular.
The reason is transformer utilization. Only half (one) secondary winding is being used so you need more copper on the transformer. It's one diode+sec winding or the other that have current flowing.
For this reason, it is higher cost even though with FWB you need two more diodes to make a bridge.
