Author Topic: Ideas for fume extractor  (Read 1695 times)
Offline grevanTopic starter
  • Country: br
« on: December 09, 2016, 07:58:41 pm »
Hi guys,
i´m developing an idea for a fume extractor.
For now i have maybe a silly question, which of these two setups do you think would have a stronger air flow power? With the carbon filter in between or before the 2 coolers?  |O :-DD
Of course i can use just one powerfull cooler, but i´tm thinking of getting not so expensive ones.
Thanks
« Last Edit: February 08, 2017, 12:57:13 pm by grevan »
Offline BobsURuncle
Re: Ideas for fume extractor
« Reply #1 on: December 09, 2016, 08:38:19 pm »
The filter in between the fans I would expect to produce more flow.  The back fan will not do much work if it is directly behind the front fan spinning at about the same rpm.
Offline Gyro
« Reply #2 on: December 09, 2016, 08:47:35 pm »
You'd be better with the two fans side by side with a filter on the output side of each. Without getting too scientific, fans always 'push' better than they 'pull'.  :D
Best Regards, Chris
Offline jonovid
    • JONOVID
« Reply #3 on: December 10, 2016, 11:15:29 am »
you could add a dust filter for a super clean air room.
& or maybe port the fan's to reduce fan blade noise.
Hobbyist with a basic knowledge of electronics
Offline Cliff Matthews
    • General Repair and Support
« Reply #4 on: December 10, 2016, 12:36:04 pm »
Pull or push, I prefer surplus centrifugal compressor-type fans for this task (and mostly, they're quieter too).
Mount in box with a circular hole to pull air through a plastic dryer hose, and let it push air through any cheap HEPA filter hot glued on the side.
