Author Topic: DC offset in microphone output? Really? Why?  (Read 5900 times)
Offline analogoTopic starter
  • Country: at
« on: November 06, 2017, 08:10:06 am »
In this video by GreatScott he shows a simple amplifier circuit made with an opamp. What I do not understand is: why does he say that applying a 2.5v offset to the non-inverting input of the opamp will create an output offset of 2.5v around which the waveform will oscillate around? Direct link: https://youtu.be/ts-JqEVzvDo?t=6m59s.
IIUC, the 2.5v input offset will _remove_ 2.5v from the inverting input, making a 0 -- 5v input voltage into a -Vrail -- +Vrail output waveform.
And even if he is right and there is a 2.5v offset in the output, isn't that a bad thing? I thought that any DC offset in bad in an audio setting.
Offline mikerj
Re: DC offset in microphone output? Really? Why?
« Reply #1 on: November 06, 2017, 08:52:17 am »
The op-amp in question is running from a single supply rail, so the output can not swing below ground.  In order to cope with an audio signal in this case you need to impose a DC offset, and for a rail-rail output amp running from 5v, you'd want this offset to be close to half the supply rail to maximise the output swing.
Since the inverting input to the op-amp is AC coupled, the DC gain at the non-inverting input is 1.  Therefore applying 2.5v to the non-inverting input gives 2.5v on the output.
Offline ebclr
« Reply #2 on: November 06, 2017, 09:08:07 am »
Offline tooki
« Reply #3 on: November 06, 2017, 12:06:53 pm »
That makes sense. But I thought that a DC offset at the output is bad (for the input of the computer or mixer, etc.)? Wouldn't you then want a DC-blocking capacitor at the output (after the op-amp, but before the signal reaches the input of the other device)?
Nice site
https://www.elv.de/journal
It is (especially old issues), but it's only available in German, which doesn't help most people here, and what does this have to do with this thread?
Offline rhb
« Reply #4 on: November 06, 2017, 04:13:54 pm »
Probably.  It depends upon what comes next.  Lots of stuff is AC coupled, but some isn't.   This can be a great source of confusion.
  • Country: at
« Reply #5 on: November 07, 2017, 08:21:30 am »
What comes next is a standard PC audio chipset. Aren't there specs that tell you "The audio signal should swing between -X volts and +Y volts, the maximum tollerable DC offset is Z volts"?
For example, the output of this amp is never going to go under 0, is this OK as an input for an audio card?
Offline ogden
  • Country: lv
« Reply #6 on: November 07, 2017, 08:48:13 am »
Specs of audio chipset indeed tell maximum signal swing, but they also say that decoupling of line-in using capacitors must be implemented. Try to google (pictures) "ac97 codec reference design circuit" and you will see - they all have AC decoupling. Yes - circuit shown in the video is not quite correct, but it will work with most PC's/mixers/amps, if not all. Only seemingly bad thing that can happen - jack detection may not work.
« Last Edit: November 07, 2017, 08:49:58 am by ogden »
The following users thanked this post: analogo
