Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Buck boost converter blowing fuses
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Buck boost converter blowing fuses (Read 932 times)
Dunk_c
Contributor
Country:
on:
October 04, 2019, 07:18:24 am »
Hi
I have a small cheap regulated buck-boost DC converter that sits between my 12v solar system and a portable lithium ion battery bank. The device is used to convert the variable battery voltage to a constant 15V required by the lithium battery bank for charging.
The B-B converter is portable for use in a vehicle so operates of a cigarette plug with fuse. Nearly every time I disconnect the battery bank the fuse blows presumably as the inductor coil fields collapse. This might be a big problem when used in the car. I don’t know if the battery is also experiencing a current surge but that would probably be bad! What is the fix for this? Can I stop it by inserting a couple of power diodes in series with the positive input and output lines?
Cheers
Logged
AVGresponding
Super Contributor
Country:
Exploring Rabbit Holes Since The 1970s
Re: Buck boost converter blowing fuses
Reply #1 on:
October 04, 2019, 05:29:18 pm »
It would help to know more, such as the fuse rating, battery pack details, solar PV details...
Logged
Zero999
Super Contributor
Country:
0999
Reply #2 on:
October 04, 2019, 07:26:07 pm »
A simple schematic would also help.
It does seem odd it's blowing the fuse when the battery is disconnected.
And what's a B-B converter? Don't you mean a DC:DC converter? EDIT: Duh, Buck Boost converter.
Last Edit: October 07, 2019, 08:57:24 am by Zero999
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
