Author Topic: diode latch  (Read 589 times)
Offline wiresahoTopic starter
diode latch
« on: May 29, 2024, 12:12:59 pm »
Is it possible to make a latch with diodes   -  I saw this ->
Or is it including transistors with it to get the memory bits?
Offline Psi
Re: diode latch
« Reply #1 on: May 29, 2024, 12:20:18 pm »
You can make gates out of just diodes, but there is no amplification, no small current able to drive larger current.
So I believe they still use transistors as buffers/inverters. Otherwise you can't series diode-based gates together without absurd current requirements from each additional gate adding more draw through the gates before it.
« Last Edit: May 29, 2024, 12:25:54 pm by Psi »
Online ledtester
Re: diode latch
« Reply #2 on: May 29, 2024, 12:23:25 pm »
A full writeup of the Diode Clock, design files and LTspice simulation files may be found here:
https://hackaday.io/project/11677-the-diode-clock#:~:text=DDL%20Devices,grab%20files%20here%3A
(scroll down to "DDL Devices")
Here is the datasheet of the hex NOR board:
https://cdn.hackaday.io/files/11677499588768/DDL01_datasheet.pdf
and here is the schematic of a NOR gate from the datasheet:
Read the datasheet for a detailed desciption of how it works. Note that V_RF is an AC source operating in the MHz range.
« Last Edit: May 29, 2024, 12:32:18 pm by ledtester »
Re: diode latch
« Reply #3 on: May 29, 2024, 01:56:48 pm »
If it didn't have inductors in it,  it would probably work hydraulicly and pneumaticly as well.
But they do have pneumatic "transistors" as well.
Online coromonadalix
Re: diode latch
« Reply #4 on: May 29, 2024, 04:50:16 pm »
lolll   wow    but consumes almost 5  amps  ...  current hungry for sure
Offline David Hess
  • DavidH
Re: diode latch
« Reply #5 on: May 30, 2024, 12:01:38 am »
Negative resistance devices can be used in place of amplification, like tunnel diodes, DIACs, or 4 layer diodes.  Neon bulbs can also be used.
Offline Psi
Re: diode latch
« Reply #6 on: May 30, 2024, 08:59:24 am »
Interesting.
