Author Topic: ID Component  (Read 1973 times)
Offline OpenCircuitTopic starter
ID Component
« on: March 21, 2017, 06:00:13 am »
Trying to ID these chips so I can proceed with testing- they read:
                                   L1213
                                   817 B
                                      W
The L is leaning to the right towards the 1 (top line)
Did search Google with numerous strings. One result was a photocoupler and the other a voltage regulator. Sorry I can't discern....I'm  learning  :palm:
Thanks for any help.
Here is a photo of the four-legged monsters:
Offline helius
Re: ID Component
« Reply #1 on: March 21, 2017, 06:15:03 am »
Lite-On LTV-817 optoisolator
Offline JoeN
  • We Buy Trannies By The Truckload
Re: ID Component
« Reply #2 on: March 21, 2017, 06:17:53 am »
You can tell it is an optocoupler just by that packaging.  I don't know anything else that gets put into that package.  Is this a power supply?  Optocouplers are very common to connect signals from the high voltage to low voltage side.
Have You Been Triggered Today?
Re: ID Component
« Reply #3 on: March 21, 2017, 06:36:30 am »
Thank you both a lot !
Joe, yes a power supply for PC (https://www.eevblog.com/forum/repair/atx-power-supply-dead/msg1166236/#msg1166236).
Offline DTJ
Re: ID Component
« Reply #4 on: March 21, 2017, 06:57:10 am »
Re: ID Component
« Reply #5 on: March 21, 2017, 07:19:23 am »
Whichever, can terminals 1 and 2 (anode cathode) be tested with a simple diode test on DMM?
Offline DTJ
Re: ID Component
« Reply #6 on: March 21, 2017, 09:56:05 am »
Yes, see data sheet page 2.
Vf = 1.25V typ up  to 1.6V max.
I'm assuming your power supply has failed?
Perhaps look at the electrolytic caps, input rectifier and switching semis.
Re: ID Component
« Reply #7 on: March 21, 2017, 04:46:35 pm »
DTJ, here is a link: https://www.eevblog.com/forum/repair/atx-power-supply-dead/msg1166236/#msg1166236
