Every electronics hobbyist sooner or later decides that he must build his own fast edge pulse generator, and I am no exception.
I'm taking one of the easiest to reproduce routes: N fast logic gates (specifically 4 x SN74LVC1G04 SOT-23-5 inverters) having series resistors on their outputs whose values are chosen so as to provide, when connected in parallel, a specific (50 Ohm) source impedance.
High-frequency effects and the respective design considerations is mostly new field to me, so I have read a lot on this topic, but obviously much still remains to be learned.
When it comes to PCB trace impedance matching aimed at minimizing reflections, it seems to be generally accepted that it's not worth bothering with as long as the length of the signal trace (from the driver's output to the output connector's center pin) is short enough for the given operating frequency. Since we're talking about 400-500 ps rise/fall times for the ICs chosen, and the expected trace length will not exceed 1-2 cm, it seems to be the case here, too.
However I want to understand the general principle without taking the "the trace is short enough" shortcut.
Suppose we need to route an output signal trace that's long enough to consider its impedance. Let's also assume that all the resistors, ICs, and their input trace lengths are perfectly matched. We then have several layout possibilities:
A: connect all the resistors in the same spot right at their respective terminals and route a 50 Ohm trace from that spot to the output connector.
B: make individual traces, 200 Ohm impedance each, from each resistor, and join them at the center pin of the connector.
C: same as B, but make each trace's impedance 50 Ohm.
As far as I understand, there are two correct options: it should be A and one of B, C.
What is the correct one between B and C and why?
Now, part 2 of what I don't fully understand, somewhat related.
On one hand, we want to match the signal trace (effectively a transmission line) impedance to avoid discontinuity. With a 2-layer board with the bottom layer used as a solid ground plane reaching the 50 Ohm target requires that the track is made relatively wide: about 100 mils for a 1.5 mm FR4 board.
But on the other hand, increasing trace width also increases parasitic capacitance to ground that the driver will have to work against, potentially increasing the edge transition times.
It looks like we have a trade-off between matched impedance (to maintain signal integrity) and transition speed here.
Initially my idea was to remove copper on the bottom layer beneath the output signal trace and the area under the output connector to reduce the parasitic capacitance seen by the drivers, but now that I have read more on this stuff, in particular, the controlled trace impedance topic, I am no longer sure that it was a good idea.
Would like to hear what would the best approach in this case be, and why.
