Hi. I'm thinking on building my own switch mode power supply and need some general advice on actually doing it.
I have played around with linear power supplies but have never really tried to do anything with a switch mode. Dave's Video #110 have really got me going, and I think it's time to design and build one.
One of the first problems getting started, is just the large number of different switch mode regulators available so using the MC34063 Dave is using would be really nice but I don't think it's possible with the specs i have in mind.
My preferred specs for my project are the following:
Input voltage: 24-32 V. I have some 24v and 32V secondary transformers laying around and I'm thinking of using one of those.
Variable output voltage: Maybe about 3V – 24V. I like to use a small microcontroller to control the output voltage (in course steps).
Max output current: Something like maybe 2A – 5A
The regulator chip has to be:
Readily available and not to expensive (whatever that means) – also applies to the external components
The complete circuit has to be relatively simple to build.
Is has to be fairly stable so I don't have to really fine tune the circuit to make it work.
Not to noisy.
If it's at all possible, I would like to make it relatively efficient.
This is just a hobby project and besides having fun doing it, I will see what else can be learned by experimenting with it. An example is noise. I'm interested in finding out what the best cheap way is to reduce output noise is and I'm thinking about maybe following it with some kind of a linear regulator, some filters or whatever works best.
If you have any suggestions on a particular chip or a family of chips, please let me know. Also any links you think could be useful, would be appreciated
/Bo
