Author Topic: LED Strip Buzzer break in void loop  (Read 2508 times)
Offline dleebellTopic starter
« on: May 13, 2015, 02:57:36 pm »
Hi
I have a set up of an RBG LED strip with a 3 RBG buttons connected with a piezo buzzer to my arduino.
I wanting to simply make a break in the void loop for when I press the Red button, the Red LED's come on and the buzzer makes one single tone and then stops, but the LED's remain on.
This is the code that I have so far.
  if (outputValueR == 0) {
    digitalWrite(outputR, HIGH);
    noTone(6); //                              tone 1
  // play a note on pin 6 for 200 ms:
  tone(6, 220, 165);
  delay (200);
  break;
I have attempted to put in a break; but I haven't managed to make this work.
Thanks
Offline electr_peter
  • Country: lt
Re: LED Strip Buzzer break in void loop
« Reply #1 on: May 13, 2015, 03:55:04 pm »
Did you turn off LED in main loop? Like this
digitalWrite(outputR, LOW);
Offline mikerj
« Reply #2 on: May 13, 2015, 05:15:46 pm »
That can't be all the code you have written so far, and without the rest of it it's impossible to say what you are doing wrong.
« Reply #3 on: May 13, 2015, 06:49:26 pm »
Hi
Yes sorry that isn't everything. Here's everything, I have tried to put in some kind of flag to have the buzzer only buzz once and LED to remain on.
  Analog input, analog output, serial output
 Reads an analog input pin, maps the result to a range from 0 to 255
 and uses the result to set the pulsewidth modulation (PWM) of an output pin.
 Also prints the results to the serial monitor.
 The circuit:
 * potentiometer connected to analog pin 0.
   Center pin of the potentiometer goes to the analog pin.
   side pins of the potentiometer go to +5V and ground
 * LED connected from digital pin 9 to ground
 created 29 Dec. 2008
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
// These constants won't change.  They're used to give names
// to the pins used:
const int analogInPinR = A0;  // Analog input pin that the potentiometer is attached to
const int analogInPinG = A1;  // Analog input pin that the potentiometer is attached to
const int analogInPinB = A2;  // Analog input pin that the potentiometer is attached to
int sensorValueR = 0;       // value read from the pot
int sensorValueG = 0;        // value read from the pot
int sensorValueB = 0;        // value read from the pot
int outputValueR = 0;        // value output to the PWM (analog out)
int outputValueG = 0;        // value output to the PWM (analog out)
int outputValueB = 0;        // value output to the PWM (analog out)
int outputR = 10;
int outputG = 11;
int outputB = 12;
int flagR = 1;
int countR = 0;
int toneR = 0;
void setup() {
  // initialize serial communications at 9600 bps:
  Serial.begin(9600);
  pinMode(outputR, OUTPUT);
  pinMode(outputG, OUTPUT);
  pinMode(outputB, OUTPUT);
void loop() {
  // read the analog in value:
  sensorValueR = analogRead(analogInPinR);
  sensorValueG = analogRead(analogInPinG);
  sensorValueB = analogRead(analogInPinB);
  // map it to the range of the analog out:
  outputValueR = map(sensorValueR, 0, 1023, 0, 255);
  outputValueG = map(sensorValueG, 0, 1023, 0, 255);
  outputValueB = map(sensorValueB, 0, 1023, 0, 255);
  if (outputValueR == 0 && flagR == 1) {  //if red is pressed and tone red gone flag is up
    digitalWrite(outputR, HIGH);    //trun on read
    flagR = 0;                      // reset flag R to off
    toneR = 1;                      // set tone falg on
  else{
  if(toneR ==1){        // make a tone for a set amount of time
     //Red tone 1
    if(countR <= 1000){        //if Red counter is below 1000
    tone(6, 220);              // play tone
    else{                      // else if red counter is above 1000
       noTone(6);             //stop tone
       countR = 0;              // and reset the Red counter to off
    countR++;                // increment read counter
  if (outputValueG == 0) {
    digitalWrite(outputG, HIGH);
  else {
    digitalWrite(outputG, LOW);
  if (outputValueB == 0) {
    digitalWrite(outputB, HIGH);
  else {
    digitalWrite(outputB, LOW);
  // change the analog out value:
  // analogWrite(analogOutPin, outputValue);
  // print the results to the serial monitor:
  Serial.print("sensorR = " );
  Serial.print(sensorValueR);
  Serial.print("\t outputR = ");
  Serial.print(outputValueR);
  Serial.print("\t sensorG = " );
  Serial.print(sensorValueG);
  Serial.print("\t outputG = ");
  Serial.print(outputValueG);
  Serial.print("\t sensorB = " );
  Serial.print(sensorValueB);
  Serial.print("\t outputB = ");
  Serial.println(outputValueB);
Although it compiled ok, it still either doesn't stop the buzzer or it doesn't work at all along with the LED.
Many Thanks for you help
« Reply #4 on: May 14, 2015, 06:00:42 pm »
Hi
I have managed to add the flag in correctly to stop the buzzer from repeatedly beeping and keeping the LED's on. I have done with with all RGB colours. I have also added a tone (ToneY) to play when two Red and Green colours show, but now have the problem of when I alternate between the individual colours Green and Red, it plays (ToneY). Basically theres the problem in the serial read where it over laps between sensorR and sensorG.
Whole Code:
 The circuit:
 modified 9 Apr 2012
 by Tom Igoe
int sensorValueR1 = 0;
int sensorValueG1 = 0;
int sensorValueB1 = 0;
int sensorValueR2 = 0;
int sensorValueG2 = 0;
int sensorValueB2 = 0;
int outputRpin = 10;
int outputGpin = 11;
int outputBpin = 12;
int flagR = 1;
int toneR = 0;
int flagY = 1;
int toneY = 0;
int flagG = 1;
int toneG = 0;
int flagB = 1;
int toneB = 0;
void setup() {
  Serial.begin(9600);
  pinMode(outputRpin, OUTPUT);
  pinMode(outputGpin, OUTPUT);
  pinMode(outputBpin, OUTPUT);
void loop() {
  sensorValueR1 = analogRead(analogInPinR);
  delay(10);
  sensorValueR2 = analogRead(analogInPinR);
  sensorValueG1 = analogRead(analogInPinG);
  delay(10);
  sensorValueG2 = analogRead(analogInPinG);
  sensorValueB1 = analogRead(analogInPinB);
  delay(10);
  sensorValueB2 = analogRead(analogInPinB);
  sensorValueR =  sensorValueR1 + sensorValueR2;
  sensorValueG =  sensorValueG1 + sensorValueG2;
  sensorValueB =  sensorValueB1 + sensorValueB2;
  sensorValueR =  sensorValueR/2;
  sensorValueG =  sensorValueG/2;
  sensorValueB =  sensorValueB/2;
  if (outputValueR == 0 && flagR == 1 && outputValueG > 0 && outputValueB > 0) {  //if red is pressed and tone red gone flag is up
    digitalWrite(outputRpin, HIGH);    //turn on read
    digitalWrite(outputGpin, LOW);
    digitalWrite(outputBpin, LOW);
    flagY = 1;
    toneR = 1;
    flagG = 1;
    flagB = 1;
    // set tone flag on
    int toneStop = 30;
    int toneStart = 60;
    for (int i = 0; i < 90; i = i + 1) {
      if (i < toneStop) {
      else if (i > toneStop && i < toneStart) {
        noTone(6);
      else {
        tone(6, 220);
      delay(10);
    noTone(6);
  if (outputValueB > 0 && flagY == 1 && outputValueG == 0 && outputValueR == 0) { //YELLOW
    digitalWrite (outputRpin, HIGH);
    digitalWrite (outputGpin, HIGH);
    digitalWrite (outputBpin, LOW);
    flagR = 1;
    flagY = 0;
    toneY = 1;
    flagG = 1;                      // reset flag R to off
    flagB = 1;
    int toneStop = 15;
    int toneStart = 20;
    for (int i = 0; i < 35; i = i + 1) {
      if (i < toneStop) {
        tone(6, 311);              // play tone
        noTone(6);
      else {
        tone(6, 165);
      delay(10);
      if (i < toneStop) {
        noTone(6);
      else {
        tone(6, 165);
      delay(10);
    noTone(6);
  if (outputValueG == 0 && flagG == 1 && outputValueR > 0 && outputValueB > 0) { //GREEN
    digitalWrite(outputRpin, LOW);
    digitalWrite(outputGpin, HIGH);
    flagR = 1;
    flagY = 1;
    flagG = 0;                      // reset flag R to off
    toneG = 1;
    flagB = 1;                       // set tone flag on
    int toneStop = 25;
    int toneStart = 30;
      if (i < toneStop) {
        tone(6, 330);              // play tone
        noTone(6);
      else {
        tone(6, 330);
      delay(10);
    for (int i = 0; i < 20; i = i + 1) {
      if (i < 10) {
        tone(6, 523);              // play tone
      else if (i > 10 && i < 15) {
        noTone(6);
      else {
        tone(6, 740);
      delay(10);
    noTone(6);
  if (outputValueB == 0 && flagB == 1 && outputValueR > 0 && outputValueG > 0) { //BLUE
    digitalWrite(outputBpin, HIGH);
    flagR = 1;
    flagY = 1;
    flagG = 1;
    flagB = 0;                      // reset flag B to off
    toneB = 1;                      // set tone flag on
    int toneStop = 30;
    int toneStart = 40;
      if (i < toneStop) {
        tone(6, 165);              // play tone
        noTone(6);
      else {
        tone(6, 330);
      delay(10);
    noTone(6);
i have already tried this below:
  delay(10);
  delay(10);
  delay(10);
But it doesn't seem to work. :(
Any help please?
