Author Topic: Controlling a pool pump with an Arduino  (Read 10253 times)
Offline rthorntnTopic starter
« on: October 01, 2013, 03:38:08 am »
Been reading a lot on this, conflicting info, various opinions so I still have no idea.
Pump is 240v Single phase 925W 1hp  3.9A
I want to switch it on/off with a microcontroller.
Right now I am thinking about using something like the Power-IO DDA-5V25 relays (it's the DDA-6V25 with internal MOV) from http://www.power-io.com/products/dda2540.htm but I am worried that the high cost combined with the shipping to Australia is going to blow the budget, I don't think I would get much change out of $150.
http://www.power-io.com/library/photos/dinrail-contactor-schematic.htm
Am I on the right track, is there a cheaper integrated snubber and MOV solution (mainly for ease of wiring and safety) that will do what I want?
Thanks.
Richard
« Last Edit: October 01, 2013, 04:01:10 am by rthorntn »
Offline David_AVD
Re: Controlling a pool pump with an Arduino
« Reply #1 on: October 01, 2013, 05:05:56 am »
Any reason you don't want to use a conventional relay to switch the motor?
A DIN rail mount contactor (big relay) would be a lot cheaper than an SSR and require no heat sink.
Offline Stonent
« Reply #2 on: October 01, 2013, 05:11:38 am »
There is a product called the power switch tail and they do have a 240v version rated for 20A. They retail for $18.50 USD.
http://www.powerswitchtail.com/Pages/PSTKKit.aspx
You probably need the international version which has screw terminals instead of a cord, since I think they just have US and Europe pre-wired versions.
« Last Edit: October 01, 2013, 05:15:47 am by Stonent »
« Reply #3 on: October 01, 2013, 05:31:48 am »
Thanks!
David_AVD: Isn't the issue there the coil voltage, I need to 5v at 40ma a lot of these are 12 or 24v?
Stonent: I did see the power switch tail but was put off by this: http://forums.adafruit.com/viewtopic.php?f=8&t=41753 in reading further in to it though the 110 volt does have double the amps and can only handle 15A though so maybe that changes it)?
Cheers
Richard
Offline David_AVD
« Reply #4 on: October 01, 2013, 06:20:02 am »
Do you only have a 5V supply?  If so, that will be a problem for a power relay.
What is the Arduino powered from?
« Reply #5 on: October 01, 2013, 06:51:37 am »
The Arduino is powered by 5v, Thanks to Stonent I have ordered a couple of the powerswitch 240v kits, going by the adafruit link I posted the 20A powerswitch derated to 40% because it's a motor load gives me 8A, I only need 4A so it will no doubt be fine.
Offline geraldjhg
  • Country: ar
« Reply #6 on: October 14, 2013, 08:37:01 pm »
yeah go for the din mounted contactor and as a bonus buy an auxiliary contactand sense if it relly closed
you could use a super small ssr for the coil only as added protection to the arduino and to keep
voltages low outside the pump enclosure
G E R A L D
Offline Kryoclasm
  • KL3DL
« Reply #7 on: October 15, 2013, 12:58:27 am »
How about an Opto coupler connected to a 240v rated 12v relay.
Use 5v to control the opto, the opto activates the 12v relay powering the 240v load.
Oh, BTW... remember to keep your grounds separate. DON'T tie the 5V grounds together with 12V Grounds.
« Last Edit: October 15, 2013, 01:10:14 am by Kryoclasm »
“I predict that very shortly the old-fashioned incandescent lamp, having a filament heated to brightness by the passage of electric current through it, will entirely disappear.” -Nikola Tesla
« Reply #8 on: October 15, 2013, 01:32:34 am »
Thanks everyone!
The 240V powerswitch tails arrived yesterday, hopefully they will do the trick.
Fairchild MOC3063 optocoupler
Zettler AZ21501-1A-240AE 40A/240VAC power relay
2 MOV's
A bunch of resistors to set the control signal voltage range
Does anybody have any concerns about this kit?
Cheers
Richard
Offline Kryoclasm
  • KL3DL
« Reply #9 on: October 15, 2013, 02:20:05 am »
Thanks everyone!
2 MOV's
Cheers
Richard
Just looking and the 240v version pic, looks like a nice kit, but look carefully at the output ground soldering through-hole... missing some solder? Might be worth inspecting yours.
http://www.powerswitchtail.com/Documents/European%20Wiring.jpg
« Reply #10 on: October 15, 2013, 02:32:56 am »
Thanks Kryoclasm!
The kit is basically a bare PCB and the components, on the live and load ends you have the option of using bare mains cable in to the larger holes or the terminal blocks in the smaller holes right beside them, what you can see in the image you have attached is the load side using a terminal block is not in the larger hole which then looks like it's missing solder.
Offline scott216
« Reply #11 on: October 20, 2013, 11:36:00 pm »
I have an Arduino controlling my pool pump and I use this solid state relay:
Carlo Gavazzi RJ1A60D50U
http://www.gavazzionline.com/pdf/rjdatasheetmidi.pdf
It works great.
« Reply #12 on: October 20, 2013, 11:39:09 pm »
Thanks scott216, how big is your pump >2hp?
Offline scott216
« Reply #13 on: October 21, 2013, 02:33:51 am »
My pump is 1.5 hp.  It pulls about 9 amps at 230 volts.  This SS relay is actually quite a bit over-sized. But I know the pump can pull a lot more when there's  a problem and I wanted the relay to handle it.
Offline chibiace
« Reply #14 on: October 21, 2013, 05:36:57 am »
im quite fond of omron relays like the g2r series
He Who Controls The Spice Controls The Universe
Offline peter.mitchell
« Reply #15 on: October 21, 2013, 08:37:32 am »
I don't see why you can't just use one of these http://www.digikey.com.au/product-detail/en/T90S1D12-5/PB109-ND/44912
