Author Topic: Op-Amp unbalanced rail voltage?  (Read 7610 times)
Offline ftransformTopic starter
« on: March 21, 2013, 07:06:04 pm »
For a dual supply op-amp are they any negative effects from having un-equal rail voltages other then having a smaller output range?
I.E. If one rail is 15.5 and the other is 14.7 is there any kind of degradation of specifications, such as PSRR, noise, bias currents, whatever.
Offline amspire
Re: Op-Amp unbalanced rail voltage?
« Reply #1 on: March 21, 2013, 07:10:38 pm »
None at all.
Offline Neilm
« Reply #2 on: March 21, 2013, 07:13:15 pm »
I've measured nA with on op-amp supplied from +15V and -8V.
No problem what so ever.
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
vlf3
  • Guest
« Reply #3 on: March 21, 2013, 08:02:53 pm »
Just need to keep in mind your supply rail to rail max, verses signal out, peak to peak before clipping.  ;)
« Reply #4 on: March 21, 2013, 08:13:37 pm »
I have seen many use a rail of -0.6V ( a diode drop above negative rail) and 11.6V as supply, just because this allowed an output to be very close to 0V, while allowing positive voltages in with no problem. Fails with an inverting amplifier though, but fine for many applications.
« Reply #5 on: March 21, 2013, 09:10:23 pm »
I swear though once I was taking measurements once and the AC measurement from my multimeter indicated that there was less noise when I increased the rail voltage from like 5 to 15.
I don't remember the setup though.
Offline c4757p
  • adieu
« Reply #6 on: March 21, 2013, 09:27:59 pm »
Op amps can definitely have different characteristics with different rail to rail voltages across them, it's the relative location of ground between them that doesn't make a difference. -1V/11V should be the same as -6V/6V, but (obviously) not -1V/1V.
« Reply #7 on: March 22, 2013, 12:50:50 am »
ah ha i am not crazy
Offline c4757p
  • adieu
« Reply #8 on: March 22, 2013, 01:00:05 am »
Also, I've seen some fantastically crappy power supplies that were noisier at low voltages (presumably due to the long wires going to the voltage pot picking up noise and not being adequately filtered), so the power supply may be injecting noise as well.
« Reply #9 on: March 22, 2013, 01:53:03 am »
This is possible my PSU is old. I really should take it apart and test capacitors at least. :--
Offline rdl
« Reply #10 on: March 22, 2013, 11:29:44 am »
w2aew has a good video on op power supplies.
