Hi all,
Today after shutting off my Dell T3610 it wouldn't power back on. The power supply passed the self test (it would make all fans spin) but the computer still wasn't powering on at all. (It's a Dell D685EF-00).
I measured the voltages at the connector and then took out the power supply to measure the voltages directly from the pins of the power supply.
From the attached image you can see the pinout of this power supply. When I measure it, the 5V at Pin 13 comes on, and the 5VSB at Pin 18 comes on until I push the self-test button where it goes to 0V. Pins 9 & 10 (red wire) stay at 0V.
The problem is I can't find any schematic of this power supply or any repair logs about it. I took it apart and nothing is obviously wrong from a visual inspection. The +12V outputs are clearly labeled, but the ground and 5V is not labeled. There is a small section over on the bottom side which is separated from the other ground pins and I was thinking this might be the 5V.
The power supply is supposed to be able to put out 4A of 5V on 5VSB, but the single pin of the power supply labeled 5VSB is going through a 220 uF capacitor - I can't imagine this is for the full 4A if it's going through such a tiny capacitor?
If anyone could help identify if this mystery section of the edge connector is in fact for 5V then i can begin attempting to track down the problem in my power supply.
Thank you if you read this far!
