Author Topic: Buying a proper solder wire  (Read 2614 times)
Offline 128ITSHTopic starter
  • Country: il
« on: December 19, 2017, 01:36:16 pm »
Hello everyone!
Its my first post here, and currently I'm setting my electronics lab - on a tight budget.
After watching Dave's soldering tutorial I searched for the type of solder wire which he (strongly) suggested to have - A fine 63/37 multi-core flux solder, and It seams to be quiet expensive. However a local store sells some Chinese solder which claims to have 2% flux in it for a much smaller price.
Is it worth buying a chip, 2% flux Chinese solder, Or should I stick with the high-end expensive multi-core flux solder wire? Maybe you know a place where I can buy multi-core flux solder for low price?
A good engineer knows how to use his tools.
A better engineer also knows how his tools work.
The perfect engineer is the one who made his tools.
Online tooki
Re: Buying a proper solder wire
« Reply #1 on: December 19, 2017, 02:48:33 pm »
This question gets discussed every few months. Do a search and read those threads. (This is always good advice before asking questions on forums, by the way.)
There isn't any real change in the solder market, so it's always the same advice: Avoid cheap chinese solder like the plague, and buy a roll of "expensive" brand-name solder (Kester, Multicore/Loctite, MG, Indium, Felder, Stannol, etc.). Depending on where you live, some brands will be way more expensive than others, so don't get stuck on a specific brand, but rather choose whichever high-quality solder brand is cheapest where you live. (Tip for beginners: Don't get solder wire with water-soluble flux, even if it's on sale. Go for rosin or no-clean.)
The ideal diameter varies depending on application and personal taste, but most people like something around 0.5-0.7mm diameter (0.02-0.03"). A roll lasts a LONG time so even "expensive" solder is a negligible expense. And some added flux (like a liquid flux pen or some gel flux) never hurts. Again, don't buy Chinese crap.
The following users thanked this post: Asuka
  • Country: il
« Reply #2 on: December 19, 2017, 04:05:55 pm »
Thanks for your answer!
Your'e right I should've searched for this question, but I didn't guessed It has already been questioned here. Now after reading more threads I see I should go on the non-Chinese brands.
