Author Topic: Help with setup  (Read 649 times)
Offline aleksdjankovicTopic starter
Help with setup
« on: March 17, 2019, 04:48:20 pm »
hello i really need help with setting up my project, I'm completely new to all of this. I have a TP4056, 2000mah lipo battery, on/off rocker switch, and string LEDs that i would like to set up so that the battery can charge when connected to a source but also power the switch for the LEDs. I detached the LEDs from their original housing so they are just the Positive and Negative wires now. Any help would be greatly appreciated. I attached a picture of what i have basically.
Offline WildMOSFET
Re: Help with setup
« Reply #1 on: March 17, 2019, 05:14:22 pm »
Just leave the battery connected to the charge controller, and put the switch in series with the LED strip.
The led + switch series must be connected to the charge regulator load output.
The terminals of the regulator are very clear, I don't think there is need for an explanation.
The following users thanked this post: aleksdjankovic
