Hi folks.
I own both the eevblog brymen and the DER EE de-5000 LCR meter, and albeit using the latter only for capacity and esr, I wondered how it could perform on resistance measuring.
Since I'm still a total beginner, I will write down what I think and what it does not sound right in my head, hopefully someone will be albe to make me understand the thing.
First of all I refer to these manuals about the specs:
Brymen, page 25
DER EE page 39-40
First of all I understand that there are two main differences in the measurement:
- The DER EE uses 4 wire connection
- when using normal R mode, the LCR calculates phase angle and a bunch of stuff to determine what the DUT is and then calculates the resistance.
Anyhow, let's focus on measuring a 1kOhm resistor. Let's also assume that its value at current temperature and humidity is 1.0000000000000000000000000 kOhms.
The range specs of the Brymen indicate an accuracy of 0.3%+2d, so what I expect is that the display has 3 decimal places (and that it will read between 0.995 and 1.005 k. Indeed the brymen shows three decimal places.
Then I go to the LCR meter. First of all I notice it has two different accuracies: one for AC resistance and one for DC resistance (DCR). I'm quite puzzled here because I do not understand the difference (perhaps it is related on how the R is measured?). But I will carry on. At 1kHz the AC resistance accuracy in the 2k range is the same 0.3%+2d (the DCR is 0.1% better though). I start wondering about where is the increased precision of a 4 wire connection. Regardless I expect the same as before. Nevertheless the LCR meter shows an extra meaningless digit, and I do not understand why! I mean if the display is 0.9979 or 0.9970 is basically the same since the last digit is not at all accurate ie meaningless.
Why is that so? Am I missing something?
I know: I should buy proper equipment to do precise measurements, but I can't afford them (and it's not as easy to score on ebay here in Italy).
Anyway thanks for reading!
Cheers
