I have a NTC-based temperature module which I connected in reverse causing its death. I thought that what was death was its 78L05 voltage regulator so I connected it again, correct polarity this time, and measured the voltage at the 78L05 output pin, nothing as expected.
Before replacing it I decided to inject 5v directly to that pin, without disconnecting the 12v, to check that the rest of the circuit still worked. It still worked but to my surprise it continued working after disconnecting the 5v supply.
Now it works normally and my question is: What caused this behavior?
