Author Topic: What is this smd component next to 5.8 antenna  (Read 795 times)
Offline Erwin RiedTopic starter
  • Country: no
« on: February 06, 2020, 12:01:21 am »
Hi, I have a small camera with a 5.8ghz transmitter that was not working properly (very weak signal) and trying to adjust the antenna ground, I desoldered (and lost) a component by mistake. Can anyone help me identify which component did I remove?:
As shown it is connected to the central pole of the antenna.
More images:
https://www.banggood.com/Eachine-TX02Pro-TX02-PRO-with-Smartaudio-AIO-5_8G-40CH-200mW-VTX-700TVL-14-Cmos-FPV-Camera-NTSC-p-1421133.html?rmmds=myorder&cur_warehouse=CN
Thanks a lot!
My website: http://ried.cl
Online xrunner
  • hp>Agilent>Keysight>???
Re: What is this smd component next to 5.8 antenna
« Reply #1 on: February 06, 2020, 12:12:34 am »
Might be an inductor ... hard to really say.
  • Country: no
« Reply #2 on: February 06, 2020, 12:24:52 am »
One hint: it is not a 0 ohm resistor. I connected one and the board gets really really hot fast.
« Reply #3 on: February 06, 2020, 12:33:38 am »
Most likely as it's unmarked a RF coupling cap. Leave it there.
The following users thanked this post: Erwin Ried
Online PA0PBZ
« Reply #4 on: February 06, 2020, 08:41:08 am »
Then it must be a capacitor, but the value is anyone's guess. If it is just coupling 100-1000 pF should work but if it is also for impedance matching it could be anything from a few pF's to 50 pF and critical.
  • Country: no
« Reply #5 on: February 06, 2020, 10:18:35 am »
I think you are correct!. I am not sure if I would be able to measure its value from a replacement I already ordered but thanks
