The brown, or the thick white is probably a piece of plastic inserted into the socket.
Insert a knife / screwdriver / other thin object - behind it and wiggle it alternating left & right in the direction of the Flex cable.
Normally these do not come out completely, but only a few mm. Then the Flex should be loose and pop out almost by itself.
