Author Topic: Cable removal  (Read 977 times)
Offline Hornnumb2Topic starter
Cable removal
« on: February 12, 2019, 08:39:48 pm »
How does the lvds cable get removed from this connector? Thanks
Online Doctorandus_P
Re: Cable removal
« Reply #1 on: February 12, 2019, 08:44:34 pm »
The brown, or the thick white is probably a piece of plastic inserted into the socket.
Insert a knife / screwdriver / other thin object - behind it and wiggle it alternating left & right in the direction of the Flex cable.
Normally these do not come out completely, but only a few mm. Then the Flex should be loose and pop out almost by itself.
Offline Yaakov
Re: Cable removal
« Reply #2 on: February 14, 2019, 09:08:51 am »
Be very gentle opening the latch, they are exceedingly easy to break—along with your heart when you do it.
Re: Cable removal
« Reply #3 on: February 14, 2019, 03:45:02 pm »
So the brown part should slide out towards cable. Right?
