one fail, each one produce one volt in good condition , like the ones used in the APOLLO 13 .
Of course if the cell is open there is not voltage and you need to return to earth cold
if the hidrogen cell is bad or not produce any power the total voltage is, I saw, 8 volts not 9!
with another batteries in U BOATS Submarines in movies similaar problem ,that is why in the submarine movies they made shortcircuits in the cells with salty water to prevent less or not voltage in the ouput.
