For a low current power supply project I need positive and negative square pulses around 200 kHz frequency. Another requirement for the square wave is to have a variable amplitude between 0-10V. Some 555 timers can provide amplitudes close to Vin, so I can vary the Vin for 555 chip and get a variable amplitude. Could you please recommend a method to convert positive pulse to negative pulse (i.e. -10V to 0V) from these or maybe another method?
I'm planning to use these as input to Cockcroft-Walton multiplier. If possible I would like to avoid using a transformer, and generate voltage (0V-100V or -100V - 0V) on the board by using 5V pr 9V DC input, without a need for negative power rail.
Thank you.
