Author Topic: calculating combination circuits for capacitance  (Read 784 times)
Offline krayvonkTopic starter
« on: June 25, 2019, 12:57:06 pm »
say I have 2 capacitors in parallel, connecting to another capacitor in series.
If you compute parallel first, its a completely different result from computing series for each then adding them together.
which way is correct?
Offline Wimberleytech
Re: calculating combination circuits for capacitance
« Reply #1 on: June 25, 2019, 01:02:54 pm »
Do the caps in parallel first.
The following users thanked this post: krayvonk
Offline pwlps
« Reply #2 on: June 25, 2019, 01:11:39 pm »
You can only use the series formula if there is nothing connected in the middle, so you have no choice but to first replace the two parallel caps by their equivalent value and then connect it in series with the third one.
