Author Topic: Voltage regulation  (Read 434 times)
Offline elkiTopic starter
Voltage regulation
« on: November 05, 2024, 09:38:00 am »
Question: I would like to make a digitally controlled 10V supply, starting from 5V from Arduino. If I were not to increase the voltage to 10V, I would use an R-2R ladder, controlled by digital pins. Is there any better way than introducing a voltage step-up regulator for each digital pin when using an R-2R ladder approach?
Offline ggchab
Re: Voltage regulation
« Reply #1 on: November 05, 2024, 09:49:31 am »
I would create a reference voltage with the R-2R ladder/digital pins and then use an op amp to obtain the right voltage.
I guess you don't need high currents ?
The following users thanked this post: elki
« Reply #2 on: November 05, 2024, 09:51:20 am »
Good idea!
« Reply #3 on: November 05, 2024, 10:08:07 am »
A follow up question: would the amplification stage work with a boost converter in case one should go to higher voltages (let's say 50V)? I am not sure how linear the response of the boost converter is in terms of output/input voltages.
Offline tooki
« Reply #4 on: November 05, 2024, 11:50:15 am »
A boost converter is not an amplifier. Its output voltage is regulated, and not a fixed multiple of the input voltage.
The way to make a digitally-controlled boost converter is to manipulate the voltage on the feedback pin.
Texas Instruments has a Java power supply design tool that includes a calculator specifically for how to design this: https://www.ti.com/tool/POWERSTAGE-DESIGNER
See page 18 of the user guide: https://www.ti.com/lit/ug/slvubb4b/slvubb4b.pdf
« Reply #5 on: November 05, 2024, 12:33:01 pm »
Thank you very much!
« Reply #6 on: November 05, 2024, 03:52:42 pm »
Sorry again, trying to understand the circuit (in the screenshot below).
I have the output voltage of 50V in my case, which I would like to digitally control. What is Vref and Vout here? I initially thought Vref can be e.g. 5V and Vout is 50V, but it does not seem it applies like this.
« Reply #7 on: November 05, 2024, 04:02:32 pm »
Sorry, I get it now!
