Author Topic: Oscilloscope transformer troubles  (Read 556 times)
Offline pitpatTopic starter
« on: May 15, 2020, 08:20:23 pm »
So, I've got this Hm-103 hameg that died on me recently, after checking every components i've found a dead bf199 transistor.
After replacing it i still got no trace so i started cheking some voltages across the board (avoiding the kv rails) and from the tranformer in the 150 ac out (from schematics spec) i get 161,6 ac.
Is it possible an increase of voltage caused by some bad components?
If the 150 ac out is gone can i step down the voltage to get again in specs?
https://cdn.rohde-schwarz.com/hameg-archive/HM103_englisch.pdf
thanks
« Last Edit: May 15, 2020, 08:45:59 pm by pitpat »
Offline vk6zgo
Re: Oscilloscope transformer troubles
« Reply #1 on: May 16, 2020, 01:19:23 am »
The nominal transformer secondary voltages are approximate.
A difference of the order you are seeing is not uncommon for a transformer which is not supplying current to a circuit.
Another reason the secondary voltage may be a bit high (even when loaded), is if the ac Mains supply in your area is high.
For these reasons, I would suggest your transformer is OK.
« Last Edit: May 16, 2020, 01:24:49 am by vk6zgo »
The following users thanked this post: pitpat
« Reply #2 on: May 16, 2020, 08:55:25 am »
Thats a great news!! now the thing is to find the faulty one.
Connected to that trace i have 2 big 2w resistors that gets proper hot (R630 and R802 on schematics) so i would guess that there's something upstream that doesnt draw enough courrent,am i right?
« Last Edit: May 16, 2020, 09:25:26 am by pitpat »
« Reply #3 on: May 16, 2020, 10:44:55 am »
ok, changed the ac main fuse on 240 ac and now im in spec, still got no trace and the big resistors are still too hot to be touched.
« Last Edit: May 16, 2020, 02:11:19 pm by pitpat »
