Hi Lee and the group,
I have repeated the analysis that I originally performed in this thread:
https://www.eevblog.com/forum/projects/dynamic-electronic-load-project/msg462562/#msg462562Using the components that were chosen by wigman27.
This is the progression of the analysis.
First I made a simplified model of the BUK954R8-60E MOSFET so that I could explore the small-signal behaviour. The small signal model does not include the gate threshold voltage Vgs. Ciss and Crss were obtained directly from the NXP datasheet. The transconductance of the MOSFET was determined from the slope of the transfer function. The current changes by 15A for 0.25V change in Vgs giving Gm=60.
AC Analysis of the MOSFET output stage:
I then added some lead inductance and resistance, this is to model the wiring between the load and the power supply under test. It is very important to include this in the model (as we will see by the results).
AC Analysis with wiring inductance and resistance.
You can see the resonance that was created when the inductance was added.
A damping circuit (snubber) was added to suppress the resonance:
The results show that the damping circuit is an effective counter measure.
I now placed the AD8630 in a test circuit to confirm the correct operation of the model:
The op-amp test gave reasonable results.
Complete control loopI then added the op-amp circuit and the MOSFET circuit together to make the complete control loop:
These are the results using the component values proposed by wigman27:
Although the control loop is stable, the phase margin is too small.
I increased R3 from 100 Ohms to 270 Ohms to reduce the gain and increase the phase margin.
The result is a very acceptable control loop.
To be continued..
Regards,
Jay_Diddy_B
