Author Topic: Old radio, old transistors, old me...  (Read 3924 times)
Offline elmontadorTopic starter
  • Country: pt
« on: May 07, 2018, 08:46:36 pm »
Hello, i have a old car radio (Blaupunkt FTZ-NR. U 108) AM FM mono, that uses 2 transistors (AD156 pnp, AD157 npn), i need to replace the transistors but its been  a headache try to find a replacement.
I found the following info online
Type Designator: AD157
Material of Transistor: Ge
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 8 W
Maximum Collector-Base Voltage    |Vcb|: 32 V
Maximum Collector-Emitter Voltage |Vce|: 16 V
Maximum Emitter-Base Voltage  |     Veb|: 10 V
Maximum Collector Current         |Ic max|: 2 A
Max. Operating Junction Temperature (Tj): 85 °C
Transition Frequency (ft): 1 MHz
Forward Current Transfer Ratio (hFE), MIN: 50
Package: TO8
the only equivalent (allegedly) i found searching the internet is NTE131 NTE135 that are also obsolete
i know that i can by on eBay old parts, but i don't want to wait a month just to find out that the transistor is a fake or does not work.
I would appreciate some advice from you guys. THANKs :-[
Offline Cyberdragon
*BZZZZZZAAAAAP*
Voltamort strikes again!
  • Country: pt
Re: Old radio, old transistors, old me...
« Reply #2 on: May 08, 2018, 09:29:30 pm »
Thanks for the info, i wanted a modern replacement (i don't care about the transistor package) so i can buy it locally, if i don't find it i think i will stick with your second link cause i am in Europe.
THANKs.
« Last Edit: May 08, 2018, 09:31:32 pm by elmontador »
Offline oldway
« Reply #3 on: May 08, 2018, 11:09:54 pm »
You could replace them by AD161 and AD162, easier to find than AD156 and AD157.
Offline exe
  • self-educated hobbyist
« Reply #4 on: May 09, 2018, 04:00:12 pm »
Why not use digikey ([1]) filter to find what parts would a good replacement? Then just look what is available on the local market (or order from digikey, they deliver to EU too, although I never tries this by myself). Or you can buy something from tme.eu, they are in Polland and offer EU delivery. Or any other available distributor like rs-online, farnell or something. Most of them have parametric search (but not many transistors in metal can enclosure, unfortunately). Although, I can't really guarantee that replacement will work the same way as AD156. But I'd try to find parts similar in collector current, power dissipation, Hfe (if possible), and maximum frequency.
[1] https://www.digikey.com/products/en/discrete-semiconductor-products/transistors-bipolar-bjt-single/276?FV=df00070%2Cdf0000d%2Cdf00011%2Cdf000d2%2Cdf00023%2Cdf00031%2Cmu2.2A%7C2101%2Cmu2.4A%7C2101%2Cmu2.5A%7C2101%2Cmu2.6A%7C2101%2Cmu2.7A%7C2101%2Cmu2A%7C2101%2Cmu3A%7C2101%2Cmu10W%7C2109%2Cmu12.5W%7C2109%2Cmu14W%7C2109%2Cmu15W%7C2109%2Cmu20.8W%7C2109%2Cmu20W%7C2109%2Cmu23W%7C2109%2Cmu24W%7C2109%2Cmu25W%7C2109%2Cmu26W%7C2109%2Cmu28W%7C2109%2Cmu29W%7C2109%2Cmu30W%7C2109%2Cmu7W%7C2109%2Cffe00114&quantity=&ColumnSort=0&page=1&pageSize=25
Offline oldway
« Reply #5 on: May 09, 2018, 04:09:43 pm »
AD161 and AD162 are germanium transistors, not silicium....A germanium transistor can't be replaced by a silicium transistor without modifications of the circuit.
A as first letter means "germanium" and B as first letter means "silicium".
The following users thanked this post: exe
« Reply #6 on: May 09, 2018, 04:20:43 pm »
I used to bung Si transistors in Ge circuits when I was a kid and they mostly worked. Worth a try. BC179 was the magic bugger that worked mostly.
Edit: those look like PA transistors. Risky business.
« Last Edit: May 09, 2018, 04:26:23 pm by bd139 »
Offline oldway
« Reply #7 on: May 09, 2018, 06:55:59 pm »
These AD's are germanium power transistors in TO66 case.
1) I doubt a lot that you could replace germanium power transistor by silicon in a classe B audio output stage : You will have serious problems of idle current with high THD because Vbe of a germanium transistor is 0.3V and that of a silicon is 0.6V
2) Even silicon power transistors in TO66 case are not that easy to find.
You find such transistors in Marantz 4240 and in Luxman SQ700X (2SD155 and 2SA616)
Offline exe
« Reply #8 on: May 09, 2018, 07:31:58 pm »
Right, I completely missed these are germanium.
If you have schematics we could try to modify it to fit modern transistors. Although, it would be interesting how it would work with silicon transistors. I'd say there should be a lot of distortion for low amplitude signal, but I have no experience with amplifiers.
Offline IanMacdonald
    • IWR Consultancy
« Reply #9 on: May 10, 2018, 05:04:53 pm »
You could probably use TIP41/42 silicon TO220 replacements so long as you increased the interbase bias voltage to just below where they start to conduct. Generally the best way to do this is to use a 'Vbe multiplier' arrangement.
It will probably work without modification but will have high crossover distortion.
Offline oldway
« Reply #10 on: May 10, 2018, 06:21:00 pm »
Non sense, you find AD161 / AD162 cheap and easy !!!
https://www.ebay.de/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xad161.TRS0&_nkw=ad161&_sacat=0
I don't know if the url will work, if not, look for AD161 on ebay.de (Germany)
« Last Edit: May 10, 2018, 06:27:33 pm by oldway »
Offline bob225
« Reply #11 on: May 10, 2018, 07:26:12 pm »
you can use silicon but you will need to adjust resistor values to suit you can get away with near spec transistors
You may want to read this page I come across on the search for AD and AF transistors info
https://www.markhennessy.co.uk/articles/vintage_transistors.htm
I have just started working on some Roberts radios my self, its a bit of a learning curve
Offline oldway
« Reply #12 on: May 11, 2018, 09:42:26 am »
In repair, we try to simplify life, not to complicate it with doubtful modifications of circuits.
Otherwise, we do not repair anything, we waste time.
The only frequent and justified modifications are to replace some lamps hard to find or expensive by LEDs.
Here there is no reason to change anything.
AD161 and AD162 can be used.
Besides the drivers transistors are probably also to replace .... AC127 / AC128 probably.
Remember that we must take precautions to solder germanium transistors....
The following users thanked this post: Electro Detective
