I am trying to calculate the power and current needed to power my laptop off a 12V battery during astronomy sessions. I would attach a Bistek 300W power inverter to the battery to convert DC to AC and plug the laptop into the AC adapter of the power inverter. The battery is an ExpertPower 12v 7ah Rechargeable Sealed Lead Acid Battery. the laptop is a Dell with a standard power adapter. How would I do the calculation to determine the current draw on the battery? I started by wondering what the current through the power inverter would be, but found my multimeter was not happy getting a resistance reading when I attached the meter probes to the leads of the cigarette lighter adapter of the power inverter (with the inverter unplugged and its switched turned on). Thanks for any help with this.
Some good advice already in this thread i'll just add a little more...
First, nothing has been said about the life of the lead acid battery so i'll mention that first.
For these kinds of batteries you have to be careful how much you discharge it. If you discharge it too low it will become useless quite fast. That's the way many lead acid batteries work. For applications like this maybe a deep discharge battery would fair better.
That said, i feel you are really following in the footsteps of the proverbial, "beating a dead horse with a stick". That's because there will be more modern solutions now. For one thing, there are probably lower power laptops available that will run much longer with a full charge. That will mean longer run time right out of the box. Second, there are mini computers out now that only use about 10 watts during the running time even with some software that uses some cpu power. This is the basic box only (about 6 x 6 x 4 inches total size, plus wall wart). You'd also have to get a small HDMI display panel and keyboard. Hard disk would be from 64GB up to around 512GB depending on the model. Total power could be under 20 watts, and some can run DIRECTLY from a 12 volt DC power supply such as a battery.
Now with that said too, back to the run time with the 12v 7 AHr battery on the laptop...
As another cute little proverb goes, "You're going to need a bigger battery".
In fact, you should probably go for a Li-ion battery not lead acid. Lead acid is too temperamental. Li-ion is much more modern and can be recharged a LOT of times. They come in 12v versions too that look just like a 12v lead acid battery. To charge you get a charger that can handle those kinds of batteries. What is also nice is you can get higher capacity with lower weight. You can start at 20AHr and go all the way up to 100AHr or more depending on your weight limitations. They are more expensive, but will last much, much longer than the lead acid counterpart. You could check Amazon to get an idea how much it would cost.
Note that with a 20AHr Li-ion battery and the 12 volt mini computer solution you could get a run time of something like 10 hours, and part of the reason for that is there would be NO converter circuits between your battery and your computer.
Good luck with whatever you decide to do, and maybe you can get back here and tell us what you ended up doing and how well it is working out.
