Newbie here. Apologies if this is the wrong section.
Hey Y'all, need to do two things to troubleshoot and insure the consistency of a roughly 25 millisecond 130v/125A weld arc. It's a one shot event every three seconds and I am looking at voltage, current, and segments of the arc time (1 millisecond to 50+milliseconds range)
1)Have been looking at cheap DSO's and have used a Fluke 199c with a current sensing ring in the past on this, but the Fluke belongs to the company I work for, is scary expensive, I don't have immediate on demand access to it, and it's easy to get lost in the menus.
2) need to measure ohms (the welder's internal resistor column) accurately from about 0.5 to 2.0 (No, that's not Kohms or Mohms - just plain ohms)- the flukes I have used are typically all over the place in this range and will give a spread of a couple tenths of an ohm over successive measurements. Have been forced to take ten readings and average and just go with that. Is there a better instrument for this?
Thanks for any suggestions,
JACIII
