A reflow oven with a good temperature control will be best in terms of reflowing correctly. Especially if you have larger components that suck up the heat on the board.
Getting everything at an equal temperature will prevent stress and failed solder joints.
That being said. If I have a one off prototype. I'll shove it on our hotplate rather than my T-962 reflow oven.
That and it doubles up as a hotplate for rework obviously.
We have the 946-1010
https://amzn.to/3wAHoglThey make them in larger sizes as well.
Personally I would skip using a toaster oven and get the hotplate. I started off with a toaster oven and while they are fine and you can get good results (I have boards working today that I made in a toaster oven nearly 8 years ago), they are just not that good enough to beat out a hotplate with a single set temperature.
We all start somewhere but IMHO, toaster ovens are really naff. After all the costs to retrofit them, hotplate from AliExpress is cheaper and better.
