Author Topic: Input offset current for op-amp?  (Read 5599 times)
Offline alex.martinezTopic starter
  • Happiness is fixing electronics by hitting them.
« on: January 19, 2017, 12:36:45 pm »
Saludos!
I've been doing some projects with a TL081 op-amp, as these are quite sensitive to errors I have a good track about theoretical real values like the offset voltage and the input bias currents. However after taking a closer look at the datasheet I've noticed an additional paramenter "Input offset current", at first sight I though "well, it is probably the offset voltage divided by the input impedance since it is so small" but I am not sure about this. I've reaserched on the forum and on the internet but I don't find any clarification on the matter. I would be very thankful if anyone could explain me what is it.
Thank you for your time,
Alex.
« Last Edit: January 19, 2017, 12:39:49 pm by alex.martinez »
Offline Aeternam
  • Country: lu
    • Schartz Engineering
Re: Input offset current for op-amp?
« Reply #1 on: January 19, 2017, 01:22:46 pm »
Alex,
The input current offset is the difference between the input currents of the two inputs. If the input stages of the opamp were 100% identical, this offset would be 0. But alas they're not, Ios is usually between 1/2 and 1/10th of Ib. Because of Ios, the opamp will see a difference voltage between its inputs even when driven by identical source impedances.
The following users thanked this post: alex.martinez
« Reply #2 on: January 19, 2017, 04:43:03 pm »
Alex,
So I guess the best way to mitigate this effect is by accounting for it together with the bias current? I use a resistor network on the non-inverting input, so I guess I just should re-calculate the values and account for that input error.
Offline Messtechniker
« Reply #3 on: January 19, 2017, 04:52:09 pm »
Sure. OK for oneoffs. But the next opamp will have a different offset.
Better go for a low offset opamp, if a low offset is important to you.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Offline rstofer
« Reply #4 on: January 19, 2017, 05:31:25 pm »
Offline Kevin.D
« Reply #5 on: January 19, 2017, 05:37:53 pm »
The param :- Average input bias current ~ This is the small current that the Op Amp sinks/sources from it's input pins. It is defined as (I non inv + I inv) / 2 .
Due to this if you feed the Op's inputs from very different impedances you will create an unwanted offset voltage when this bias current flows through these different impedances. So try to keep the input impedance of the input circuitry the same on both inputs and the offset voltages will tend to cancel out.
Bias Input Offset current:- is the difference in bias current between the input pins. Now a lot of newer op-amps (like 0p07 op27 series) are designed with input bias current cancellation. For these parts the input bias current is a very low and temp stable  and the input bias offset current in these devices is nearly equil in size to the input bias current (thats how you can tell if Op is using internal  bias cancelation) . When these two params are nearly equal in magnitude you should not use impedance equalizing resistors in these opamps as you can end up making the offset current effects worse than the average input bias current effects.
Here's a link, note page 3 in particular :- http://www.analog.com/media/en/training-seminars/tutorials/MT-038.pdf
Regards
Offline Zero999
  • 0999
« Reply #6 on: January 19, 2017, 06:40:51 pm »
Saludos!
Alex.
Why are you using the TL081?
Do you have very high input impedances?
Unless the impedances imbalance at the inputs are over 10M, or the IC is very hot, the voltage offset will be much greater than the offset due to the bias currents, even if the offset current is ignored.
Worst case figures  for the TL081 @25oC:
VOFFSET = 15mV = 15×10-3
IBIAS = 400pA = 400×10-12
Source: data sheet
http://www.ti.com/lit/ds/symlink/tl084.pdf
Calculate the input impedance imbalance would be required to create a voltage difference of 15mV
R = VOFFSET/IBIAS = (15×10-3)/(400×10-12) = 37.5×106 = 37.5MOhms
If you're having problems with the offset, it's most likely because, being a JFET amplifier, the TL081 has a poor input offset voltage specification. Try changing to the OP07.
« Reply #7 on: January 19, 2017, 11:58:08 pm »
Maybe this will help:
http://www.ecircuitcenter.com/Circuits/op_ibias/op_ibias.htm
Read the article, thank you a lot! So Ios = Ib+ - Ib-, yeah I studied in the degree that these bias currents are different, but always neglected their effect, as they are usually of the same order of magnitude. I'll try to play with the values later ahead.
Regards
What do you mean by input impedances? As far as I've been taught the chip has a given input impedance which is increased by the closed loop gain. So those input pins have actually different impedances?
Saludos!
Alex.
Source: data sheet
Well, the TL081 is cheap here (and ine of the few Op-amps I can get with ease), actually the offset voltage is of no concern to me(SW and GBW are the main parameters I take into account), I'm just interested in the AC part of the signal (I just plug a coupling cap), but I was curious how that might affect the output, it is nice to know what would happen to the design at any stage and frequency.
As I have understood that would be the imbalance between the inverting input and non-inverting input impedaces, isn't it?
Thank you for your replies!
« Last Edit: January 20, 2017, 12:11:39 am by alex.martinez »
Offline Kevin.D
« Reply #8 on: January 20, 2017, 10:33:57 am »
External impedance's , what you see when looking out from the op's input's .
Offline Zero999
  • 0999
« Reply #9 on: January 20, 2017, 08:58:37 pm »
With high input impedances, at AC, the input capacitances of the op-amp contribute to it, especially with a JFET op-amp but I couldn't find a specification for the TL081's input capacitance.
What are you trying to do? Please post a schematic.
Offline suicidaleggroll
« Reply #10 on: January 20, 2017, 09:08:42 pm »
This statement is a little confusing, so my comment is just for clarification.
The input bias current and input offset currents listed in the datasheet are average/max of the absolute value of that parameter using a large sample size of parts.  When the datasheet says the bias current is "1 pA", it doesn't mean it's absolutely +1 pA, it means it could be anywhere between -1 pA to +1 pA.  You can't pre-calculate resistor values to compensate for it.  You CAN buy the op-amp, measure the bias current for that exact unit, then design a compensation circuit for it, but that compensation circuit would only be applicable to that exact unit.  As soon as you build a second board, you'll have to re-calculate all of the values, otherwise your "compensation" could actually make things worse if that unit has a bias current in the opposite direction.
Same goes for offset current, offset voltage, etc.  Also the bias current, offset current, and offset voltage all change as a function of temperature, they are not fixed.
« Last Edit: January 20, 2017, 09:10:15 pm by suicidaleggroll »
« Reply #11 on: January 20, 2017, 10:15:18 pm »
Okay, got it! Thank you all very much ! ^^
Offline Zero999
  • 0999
« Reply #12 on: January 20, 2017, 11:56:29 pm »
One important thing to note is the polarity of the bias current depends the op-amp's input stage. If it has bias compensation or a rail to rail input, then it can be either positive or negative, otherwise it will always be either positive or negative. An op-amp with an N-channel JFET or NPN BJT input stage will always sink current, where as one with a P-channel or PNP input stage will always source current.
The following users thanked this post: suicidaleggroll
Offline danadak
« Reply #13 on: January 21, 2017, 01:39:32 am »
From one of the experts in the industry, page 2 or 3 has a clickable link page for bias current
and other anomalies one has to deal with.
https://www.ti.com/ww/en/bobpease/assets/www-national-com_rap.pdf
Regards, Dana.
Offline bson
« Reply #14 on: January 21, 2017, 07:56:47 pm »
It's more something you can use for monte carlo analysis to account for unit variance, to determine the resulting variance of your assembled circuit.  Conversely, it's also something you can determine an upper bound for as a parts requirement.
