Author Topic: CAMA-AFM31 USB Capacitive Fingerprint Module with FPC1020 pin configuration  (Read 1108 times)
Offline akashmittal
  • Country: in
I have a CAMA-AFM31 USB Capacitive Fingerprint Module with FPC1020. I am new to it and i cannot figure out what its pin configuration is. I have searched everywhere but am unable not find its datasheet. I just need to figure out its power, ground and tx/rx pins.Please can someone provide me with some help? I have attached the necessary pictures of the module.
Thanks in advance.
« Last Edit: April 09, 2017, 01:52:32 pm by akashmittal »
Offline akashmittal
  • Country: in
Thank you for your reply :)
Actually I have the documentation for the fpc1020 fingerprint sensor, and I require the documentation of the module (CAMA-AFM31). As the fingerprint sensor is already programmed and connected to the module, I only need to figure out the pins of the module (CAMA-AFM31).
