This might be an incredibly dumb question....
I have a controller that operates the door to the hen house, the controller itself is "VSB Electronic doorkeeper"
https://gb.axt-electronic.org/uk_shop/...
... now the door opener itself is powered by 4 AA batteries i.e. around 6V
... and the controller has two pins.. pin 3 and pin 4
Pin 3 and Pin 4 go to a timer which is a 24hr clock where some segments are ON and others are OFF. The timer either is open circuit or close circuit for the corresponding ON or OFF state.
I would like to create a gadget that goes between the timer and the controller such that I can have a manual OPEN and CLOSE button. OPEN would make Pin 3 & 4 open circuit until the timer next changes state and then it would follow the timer, CLOSE would make Pin 3 and 4 connected until the timer changes state and then it would follow the timer. I would power the gadget from the controller 6V.
Now... So Pin 3 and Pin 4 are open or closed... so there must be a voltage across these two pins and the current that flows determines whether the mode is OPEN or CLOSE.
How can I add a solid state circuit to Pin 3 and Pin 4 such that polarity isn't important and such that I don't insert any un-necessary voltage bias? (I don't want to use a mechanical relay due to the power requirement.)
I read a bit about Triacs but these seem more suited to controlling big AC loads. If I use a MOSFET then polarity will be significant?
Any guidance appreciated
Regards
Nivag
