Author Topic: Can amplifier output impedance or highpass cutoff change by loading?  (Read 919 times)
Offline fonographTopic starter
  • Country: at
I have two questions,can capacitor coupled amplifier -3db point,I mean how high does the high pass filter cut off,change depending on impedance of the load? And same question,just this time if the amplifier output impedance can change depending on impedance of load.
I dont see how any of this would change,but I am not so sure anymore when its highly complex circuit with bunch of feedback or feedforward loops.I ask becose I read some specifications that gave the capacitor coupled amplifier lower
frequency cut off with added number of impedance of load that was tested with,that made me think,what if this cut off change depending on impedance of load.
Offline The Soulman
  • The sky is the limit!
Re: Can amplifier output impedance or highpass cutoff change by loading?
« Reply #1 on: November 29, 2018, 12:47:49 pm »
The first question is simple, substitute load for R and calculate for R-C filter.
If load impedance (R) changes with frequency or temperature or..... you have
a lot more points to calculate.  :)
Second question, it shouldn't, but there are way to meany variables here to give a use full answer.
Do you have specific application and schematic?
The following users thanked this post: fonograph
  • Country: at
« Reply #2 on: November 29, 2018, 06:46:13 pm »
I dont have anything specific.
