Author Topic: Can an ESD create a current path?  (Read 1895 times)
Offline int6hTopic starter
  • Country: ru
« on: August 02, 2018, 10:07:23 pm »
Since plasma is conductive, can a spark of ESD create a current path in a spark gap?
Offline CopperCone
  • *knock knock*
Re: Can an ESD create a current path?
« Reply #1 on: August 02, 2018, 10:09:52 pm »
yes look at tubes like krytron
The following users thanked this post: int6h
  • Country: ru
« Reply #2 on: August 02, 2018, 10:35:53 pm »
Thanks for the answer.
Can it be dangerous for HV electronics? I mean, you're not supposed to put your finger in there anyway, but other surfaces can also create ESD.
Offline JustMeHere
« Reply #3 on: August 03, 2018, 01:51:53 am »
Absolutely.   Watching lightning real close.
Offline exe
  • self-educated hobbyist
« Reply #4 on: August 03, 2018, 03:59:35 pm »
I think so, check this out: (spoiler alert: exploded light bulb destroyed MCU)
Online Gyro
« Reply #5 on: August 03, 2018, 07:54:22 pm »
The closest example I can think of, off hand, is old CRT TVs. I remember reports in repair magazines where a low current EHT flashover had triggered a very destructive arc across the low voltage HT mains derived supply.
« Last Edit: August 03, 2018, 08:31:16 pm by Gyro »
Best Regards, Chris
Offline David Hess
  • DavidH
« Reply #6 on: August 06, 2018, 01:37:05 am »
That is exactly how triggered spark gaps work.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: August 06, 2018, 09:08:48 am »
Ah, but that's probably not "low current", because EHT is supported by the ~500pF capacitance of the CRT glass.  Indeed, HV strikes in CRTs were a not-infrequent occurrence -- due to impurities flaking off inside the bulb, or excess gas -- and ESD protection was usually seen, usually a GDT (or three) on the socket.
I traced the signal path in a Trinitron monitor once, it's got one GDT for each cathode (the cathodes are driven with video, about 50V at ~100MHz bandwidth), and series carbon comp resistors (presumably, the lowest value possible without impairing the bandwidth, 22 ohms).  The driver itself has small clamp diodes, so there's double protection.  The driver is a bipolar IC, internally an emitter follower driving the output pins; it would have some capability for transient handling, but not much considering the small feature size of high voltage RF transistors used.  In short: it's designed to withstand, essentially, 30kV machine model ESD, while maintaining a 100MHz analog bandwidth -- a challenge by any means!
Seven Transistor Labs, LLC
The following users thanked this post: exe
Online Gyro
« Reply #8 on: August 06, 2018, 11:08:18 am »
Yes indeed!
Irrc, these reports were more along the lines of poorly routed / degraded / dirty EHT leads and intermittent tube outer coating ground spring connections arcing to the board - older cheaper stuff. Internal tube flashover to cathode(s) were normally better protected, even on the cheaper sets (PCB slot gaps etc.)
EDIT: Useless unrelated fact warning: B&O used to use Philips southern hemisphere CRTs upside down to move the EHT cap to the bottom, thus enabling them to thin down the cabinet profile at the top. Unfortunately this lead to rather close proximity between the EHT connection and the electronics.
« Last Edit: August 06, 2018, 11:24:37 am by Gyro »
Best Regards, Chris
