Just want to chime in with my first post, hot glue is ok as long as the internal temperature of the device in question is relatively low. For example you shouldnt have any problems with your telephone adapter and most equipment. But when it comes to hot stuff, like amplifiers and such, I much rather use standard silicon, because even if hot snot wont completely melt, it will become soft as temperature rises, so it may actually unglue from say a PCB and such.
When i was recapping some old equipment which used Axial capacitors, i used Radials instead, and i glued them to the pcb with hot snot, after a few minutes of using the device, all caps unglued from the pcb due to increased temperature.
